12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoHi Tricky.
All the simulations went well. I attached all the code in the case someone wants try it too: UART.vhd is the main. FIFO_mf.vhd is the FIFO mega function, 16 bytes. rx_uart.vhd is the rx 115200 bps. mod_27_uart.vhd is the modulator from 50MHz (DE2-70) to 1.84KHz (UART). I have a altera board DE2-70 which I will load the code (UART.vhd is the main) after compilation. UART.vhd will give me this in/outputs: ENTITY UART IS PORT ( rst : IN STD_LOGIC; -- whole system reset. serial_rx : IN STD_LOGIC; -- the data being received serially. clock_50MHz : IN STD_LOGIC; -- whole system clock. rd : IN STD_LOGIC; -- FIFO outputs the first byte saved from UART when it is '1'. full : OUT STD_LOGIC; -- when FIFO is full. empty : OUT STD_LOGIC; -- when FIFO is empty. mod_27_cnt : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); -- 1.8KHz uart (115200 bps). parallel_rx : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); -- parallel rx from uart_rx to FIFO_mf. usedw_out : OUT STD_LOGIC_VECTOR(3 DOWNTO 0) -- just a counter of FIFO. ); END UART; I used the Quartus II to associate those pins above from UART to the FPGA: rst is a switch on the board. serial_rx is the serial rx on the board DE2-70. clock_50MHz is the 50MHz clock from the board.. rd is a button fr mthe board. full is a red led from the board. empty another red led. mod_27_cnt not associated, it is just for simulation visualization. parallel_rx is associated to 8 green LEDs . usedw_out not associated, it is just for simulation visualization. After load the code to the board, I opened the terminal (I use one from arduino app) and reset the switch (rst) on the board. After, for testing, I write 1 on the terminal, then 2, then 3. Then, I pressed the button (rd) and nothing happens. The green leds would expected to be flashing the 1 binary at first press. Then the 2 binary after second pressing. The same with 3 binary. It happens in the simulation with ModelSim Altera. As I am a newbie with FPGA, I would expect the simulations, as soon as they are synthesizable, happens in the board too. I attached the schematic from qartus II to help to visualize it. All the role are played (I think it is) by the mod_27_uart, that starts to count from 0 to 12 (ignore the 14 in the image, I correct it) to detect the start bit, and from 0 to 12 twice to detect each of the 8 data bits, and finally to 0 to 12 to detect the end bit. The mod_27_uart only starts to cout when the start bits on uart_rx is detected, so it is why the uart_rx controls the reset of the mod_27_uart. Please could some experienced help me with this issue? I appreciate your help.
