Matthias0
4 years agoTiming Constraints and TNS
Hi there,
my current Design has a TNS of 0.175ns which i cant get rid of.
i tried to constrain all of my paths with some reasonable values:
But no matter what i enter for the fou...
sstrell
4 years agoWithout seeing the complete timing report for that path (full path detail level), you have a relatively large clock skew there. You're transferring data between two clock domains (spi_clk to clock), so perhaps you need multicycle timing constraints or to add registers. Is this within an IP or just your own logic? More detail about the failing path and your design needed.
