14 years agoTimequest waveform window has disappeared
All,
Maybe I am doing something daft but my Timequest waveform and path windows have disappeared. I have just upgraded to Q11.1 SP2 from Q10.1SP1. Normally I would do... 1)Report Setup Summary create_timing_summary -setup -panel_name "Summary (Setup)" 2) Then report timing on the failing paths report_timing -to_clock { scl_clk_int } -setup -npaths 10 -detail full_path -show_routing -panel_name {Setup: scl_clk_int} I normally expect a list of each path to come up with the waveform and full path showing you the delays for the data required and data arrival paths. This is not coming up. All I see is what is on the picture I have attached. When I go back to 10.1, the waveform and path windows are missing from there also. Anyone seen this or know how to get it back. :confused:
