13 years agoTimeQuest Timing Analyzer[Setup slack analysis]
HI, I am trying to understand how the Time Quest analyzer calculating required setup and hold time.I have written code for register and the clocks are common(50 MHz). As per my understanding da...
10 years agoI find TimeQuest is using "Incr" for showing the Waveform
So the uTsu 0.021 is actually -0.021 --- e.g. you can set a output delay max tsu. min -th. for an output pin it will shows -tsu, th in "Incr" table in TimeQuest
