13 years agoTimeQuest Timing Analyzer[Setup slack analysis]
HI, I am trying to understand how the Time Quest analyzer calculating required setup and hold time.I have written code for register and the clocks are common(50 MHz). As per my understanding da...
13 years agoAs you wrote "setup slack = clock arrival time -Tsu - Setup Uncertainty".
Setup uncertainty = 0.2 ns Tsu = -0.21 ns So, you get setup slack = clock arrival time -(-0.21) -0.2 = clock arrival time +0.21 -0.20 The incr colum is the slack's increment. So, it lists +0.21 and - 0.20 respectively.
