--- Quote Start ---
the value depends on the requirements of the receiving device. Are the data latched in with the pos- or negedge ? What is the required setup time ?
Kind regards
GPK
--- Quote End ---
Hi GPK,
I'm not really too concerned about the value - I don't understand the meaning. Here's a picture that might simplify this discussion:
http://photosbybruce.smugmug.com/photos/749483837_kenbm-m.jpg The constraints I entered for Quartus were:
create_clock -period 30 [get_ports CLK]
create_generated_clock -source [get_pins {EXT_CLK~0|combout}] \
-master_clock [get_clocks {CLK}] [get_ports EXT_CLK]
set_input_delay -clock EXT_CLK -clock_fall 8 [get_ports {DATA_IN}]
set_output_delay -clock EXT_CLK 2 [get_ports {DATA_OUT}]
These constraints give my intent for the design. But when I analyze the design with TimeQuest and output the report_ucp,
I get the following:
; Unconstrained Paths ;
; Unconstrained Paths Summary ;
; Property ; Setup ; Hold ;
; Illegal Clocks ; 0 ; 0 ;
; Unconstrained Clocks ; 0 ; 0 ;
; Unconstrained Input Ports ; 1 ; 1 ;
; Unconstrained Input Port Paths ; 1 ; 1 ;
; Unconstrained Output Ports ; 1 ; 1 ;
; Unconstrained Output Port Paths ; 2 ; 2 ;
; Clock Status Summary ;
; Target ; Clock ; Type ; Status ;
; CLK ; CLK ; Base ; Constrained ;
; EXT_CLK ; EXT_CLK ; Generated ; Constrained ;
; Setup Analysis ;
; Output Port ; Comment ;
; EXT_CLK ; No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment. ;
; From ; To ; To Clocks ;
; CLK ; EXT_CLK ; CLK ;
; From ; To ; From Clocks ;
; CLK ; EXT_CLK ; ;
; toggle ; EXT_CLK ; CLK ;
; Hold Analysis ;
; CLK ; EXT_CLK ; ;
Am I missing an important constraint? What do I need to change to make these unconstrained ports and paths go away?
Bruce
