12 years ago --- Quote Start --- I'm a bit surprised the clock enables are that much worse. If you used enables, you would have one global clock line toggling at 320MHz and then a lot of logic that gets enabled/disabled. --- Quote End --- Whoa, but won't I have to specify multicycle setup and holds for every single path on those enabled clocks? That's going to be a nightmare for 32+ divided down clocks, no?
