Testing each bit in memory device. . . failed at address 0x800AB8
I have using a CYCLONE LP 10 CYC1000 FPGA Development Board and testing sdram
Testing RAM from 0x800000 to 0xFFFFFF
-Data bus test passed
-Address bus test passed
-Byte and half-word access test passed
-Testing each bit in memory device. . . failed at address 0x800AB8
Press enter to continue...
I am getting this error
I am using Quartus Prime Lite 18.1.625 Windows
Please suggest what could be wrong
Arun
- sstrell
Where are you getting this error? What are you using to test? How is the design set up?
- AdzimZM_Altera
Hi Arun,
Are you using your own custom design or Intel IP?
What is the program that has been used to test the design?
Adzim
- RARUNKUMAR
I am using Intel IP platform designer only and memory test generated from Nios
- EBERLAZARE_I_Intel
Can you provide a screenshot of the error that you faced?
Any update from your side?
