Ken_I_Intel
7 years agoSystem Verilog Pass typedef struct packed between modules Error (12002): Port "X" does not exist in macrofunction "Y"
Hi, I started to use typedef struct packed in my simulation no problems. However when I try to pass compile the and pass a struct it gives an error message. I just assumed I could pass a struct as...
GuaBin_N_Intel
Contributor
7 years agoI compiled your same HDL coding without any issue in Quartus Standard version18.1. Also, I tried to duplicate the 2nd issue you had but not succeed. It could compile even the source file put at different place than its project directory.
logic a;
logic b;
} t_ab;
endpackage
import types_package::*;
module foo (
input sys_clk,
input t_ab test_ab,
output foo_out
reg foo_out_r;
assign foo_out = foo_out_r;
always@(posedge sys_clk)
foo_out_r <= test_ab.a & test_ab.b;
endmodule
module struct_test (
input sys_clk,
input top_a,top_b,
output wire test_out
t_ab test;
assign test.a = top_a;
assign test.b = top_b;
foo foo1(
.sys_clk (sys_clk),
.test_ab(test),
.foo_out(test_out)
endmodule
