Synthesize NIOS II with different .qsf and no time_limited
Hi FvM, Kelly,
Thank you for your answers!
Yes: DE1-SoC (Cyclone V with ARM SoC). In the FPGAcademy courses ( https://fpgacademy.org/courses.html ) they support both ARM and Nios and we have to support Nios II. The project I am trying to synthesize is the "University Program" that Intel provides for Nios II on DE1-SoC.
I had read that Nios II/e had some limitations in floating point and I am not sure if these limitations can affect the projects professors work with; so I would prefer, if possible, to stick with the original configuration if possible.
I have just downloaded the Quartus Prime Standard 22.1std.1 with the 90-day evaluation license, but I see that this also generated the DE1_SoC_Computer_time_limited.sof file. In theory with the Standard version it should be enough, or do I need any further license of an IP or similar?
Thank you!
