8 years agoState Machine Viewer - missing transition
Hello every one, can you explain me why I get different state transition diagram from relatively the same VHDL? Here is the code: 1) if rx_bit_in...
8 years agoHi Vikas,
thank you for the quick answer. May be I didn't explain enough what I am doing the two IFs are within a CASE within a PROCESS So: p_UART_RX : process(CLOCK) begin if rising_edge(CLOCK) then case rx_state is when........................... --FIRST VARIANT when s_rx_data_bits => if rx_clk_count < g_CLKS_PER_BIT-1 then rx_clk_count <= rx_clk_count + 1; rx_state <= s_rx_data_bits; rx_smp_tick <= '0'; else rx_clk_count <= 0; rx_data <= rx_stable & rx_data(7 downto 1); -- LSB first --rx_data(rx_bit_index) <= rx_stable; -- Wait g_CLKS_PEBIT-1 clock cycles to sample serial data rx_smp_tick <= '1'; if rx_bit_index = 7 then -- !!! rx_bit_index <= 0; rx_state <= s_rx_stop_bit; else rx_bit_index <= rx_bit_index + 1; rx_state <= s_rx_data_bits; end if; [/INDENT] end if;[/INDENT] --SECOND VARIANT when s_rx_data_bits => if rx_clk_count < g_CLKS_PER_BIT-1 then rx_clk_count <= rx_clk_count + 1; rx_state <= s_rx_data_bits; rx_smp_tick <= '0'; else rx_clk_count <= 0; rx_data <= rx_stable & rx_data(7 downto 1); -- LSB first --rx_data(rx_bit_index) <= rx_stable; -- Wait g_CLKS_PEBIT-1 clock cycles to sample serial data rx_smp_tick <= '1'; if rx_bit_index < 7 then --THE DIFFERENCE IS HERE rx_bit_index <= rx_bit_index + 1; rx_state <= s_rx_data_bits; else rx_bit_index <= 0; rx_state <= s_rx_stop_bit; end if; [/INDENT] end if;[/INDENT] when........................... when others => rx_state <= s_rx_idle; [/INDENT] end case;[/INDENT] end if; end process p_UART_RX; THE both variant have the same behavior but in the state machine viewer the transition stroke are missing for the second, and I do not understand why? Else the both code work correctly and a signal tab show correct transitions Regards, Emil
