16 years agoSOPC-Builder does not create <Name>_sim.mpf file
I would like to simulate my Project with ModelSim. For that I generate my system with the option "Simulation. Create project simulator files" turned on in the SOPC-Builder.
Some lines of the SOPC-Builder output (don't know if important):
No .sopc_builder configuration file(!)
Building ModelSim Project
Das System kann den angegebenen Pfad nicht finden
HDL Simulation Directory : C:/SVN_Repos_Prakt_FPGA/altera_projects/Project/Project_system_sim
System generation was successfull.
When I now klick on "Run Simulator" I get the error: Could not find the simulator file Project_system_sim.mpf in C:/SVN_Repos_Prakt_FPGA/altera_projects/Project/Project_system_sim Info: If you have not set the HDL Simulator Path (under Tools > Options), do so and regenerate. This path is set to: C:\Altera\91sp1\modelsim_ase\win32aloem and should be correct. When I try to start the simulation via NiosII-IDE (Run as --> ModelSim) then ModelSim opens and shows the error: # vsim -gui Project_system_sim.mpf # ** Error: (vsim-19) Failed to access library 'Project_system_sim' at "Project_system_sim".# No such file or directory. (errno = ENOENT)# Error loading design
I think this is because the _sim.mpf file was not created by sopc-builder. Any idea why? I'm using Quartus II 9.1 SP1 and ModelSim 6.5b. I do not have a subscription license. Thanks!
