15 years agoSize of parameter
I'm building DDR SDRAM controller for DK-START-3C25N board. I have originally set size of FSM register as 6 and specified parameters of FSM states with size 6. But then I reduced size of state machine register to 4 thus parameter's size was reduced either:
reg[3:0] fsm_state; ............................... parameter [3:0] // FSM states IDLE = 4'h0, MRS = 4'h1, SR = 4'h2, AR = 4'h3, RA = 4'h4, READ = 4'h5, BS = 4'h6, WRITE = 4'h7, READA = 4'h8, WRITEA = 4'h9, PC = 4'hA; However during compilation Quartus outputs the following warning messages: Warning (10230): Verilog HDL assignment warning at parameters.v(3): truncated value with size 6 to match size of target (4) .................................. Warning (10230): Verilog HDL assignment warning at parameters.v(13): truncated value with size 6 to match size of target (4) Looks like it still treats parameter's size as 6 even though I've changed it to 4 and FSM register size is also 4. Even though this warning does not cause any harm and final design works I still would like to know the reason for this warning. Any suggestions are very welcome. I'm using Quartus II 9.0 Web Edition.
