17 years ago --- Quote Start --- Hi, Is it possible to get SignalTap to use external memory for data logging? I got 256MByte of DDR2 memory in my NIOS system, using the Altera DDR2 memory controller. Logging traces to this memory could be usefull, when debugging slow but long signal patterns, e.g. a complete PAL/NTSC video frame signal. BR Peter --- Quote End --- Hi Peter, as far as I know it is not possible to use an external memory for Signaltap. Maybe you can reduce the number of signals so that a frame fits into the internal memory ? When you have access to FPGA pins on your board a Logic Analyzer could be an option. For a logic analyzer you can use the LAI (Logic Analyzer Inferface) feature or route the required signals with "signalprobe" to the pins. Tools -> Logic Analyzer Interface Editor Tools -> Signalprobe pins
