AEsqu
Contributor
4 years agosignal tap: pre-sythesis shall be named post-synthesis
It is possible to probe signal tap using
pre-synthesis or post-fitting results from quartus.
This is actually not correct,
if you run compile only, you cannot probe the "pre-synthesis...
SyafieqS
4 years agoHi Alex,
by definition vqm is already synthesized by third party as mentioned but it need to get integrated with Quartus flow thus a compilation is necessary
