17 years agoIf you are doing a source synchronous bus, i.e using your clock60 as the clock that latches your data in to your external fifo then you probably want to use the -reference_pin command in your output delay. The reference pin is the name of the actual output port that your clock goes out on. The required timing is then calculated with respect to this latch edge then.
example set_output_delay -clock { clock_that_clocks_out_your_data } -reference_pin [get_ports {your_clock60}] -min -4 [get_ports.......
