12 years agoThank you for all the replies. I still need to digest the information..
Another question related to my example Case 1 create_clock -period 20 [get_ports { RX_CLK }] set_input_delay -clock { RX_CLK } -clock_fall -min $uC_tCOmin [get_ports { RC_Data0 }] set_input_delay -clock { RX_CLK } -clock_fall -max $uC_tCOmax [get_ports { RC_Data0 }] Adding this constrain removes the slack violation for hold time (shown in previous msg) using case 1 above but I am not quiet sure how these 2 constrains work together (even after reading the TQ guide) |Data_out[31]} is the receiving FF of the shift register set_min_delay -from [get_ports {RC_Data0 }] -to [get_registers {RCVR_Part|Data_out[31]}] -6 I want to clarify that the RC_Data0 is also an output to another pin of the FPGA (pin to pin -no logic) . The timing of the out pin is not critical at all. The important timing is the latching of RC_DAT0i to the first FF of the shifregister Input pins to FPGA Internal logic ---->>RX_CLK -----------------------> shiftReg1_FF-clk ---->>RC_Data0-----------------------> shiftReg1_FF-Q | | | Outpin of PFGA |------------------>> RC_DAT0 thank you
