set get_device_family [get_parameter_value DEVICE_FAMILY]
- 4 years ago
Hi mingcan,
I tried with simple tcl script of device_family and it worked well.
package require -exact qsys 15.0 (14.0 and 16.0 both also worked)
Quartus lite version 21.1
Hi mingcan,
Try to use command 'get_project_property' instead of 'get_parameter_value'. The error still persist?
Sheng
Invalid command name ''elaboration_callback'' most probably due to not being enabled. Should be first enabled with - set_module_property ELABORATION_CALLBACK elaboration_callback. Can refer manual below page 26.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_components.pdf
- MingBai4 years ago
Dear,
I've confirmed that "elaboration_callback" is enableed.The format of my script is similar to the example in the manual below page 26."get_project_property" work not well.I want to get fpga device by tcl script.- ShengN_altera4 years ago
Hi mingcan,
Dear,
Thank you very much.
I hope more FPGAer will see this topic.
