14 years ago
set_false_path -fall
I have an asynchronous reset_n (active low) signal.
It goes through a couple of flops to result in an asynchronous assertion, synchronous de-assertion signal. Something like this: assign pclk_reset_n = pclk_reset_n_dd & reset_n;
I want to ignore the timing of the falling edge of pclk_reset_n, but I do want timing analyzed on the rising edge of pclk_reset_n, but I'm not sure how to write the constraint...
I would have thought I could use something like (with -fall):
set_false_path -fall -from reset_n
but I don't see it listed in the Altera SDC manual.
Any suggestions?
Torrey
1 Reply
    You don't need to.
    TimeQuest checks recovery/removal of involved registers at reset deassertion only
