amildm's avatar
amildm
4 years ago
seed -> how to get same SOF for each compilation run?
Hi All, Each time when I compile the design, I'm getting the different SOF files even I don't change anything neither in my Design nor in QSF... the resulting SOF will be different... Sho...
  • ak6dn's avatar
    ak6dn
    4 years ago
    The source files drive the logic generation / mapping phases.
    So if you compile with the exact same sources, the logic produced will be exactly the same.
    The SEED value only drives the fitter.
    Different SEED values will produce different placements of the exact same logic.
    So if you don't change the source files, the logic will be the same.
    If you don't change the seed, the placement will be the same.
