seed -> how to get same SOF for each compilation run?
- 4 years ago
The source files drive the logic generation / mapping phases.
So if you compile with the exact same sources, the logic produced will be exactly the same.
The SEED value only drives the fitter.
Different SEED values will produce different placements of the exact same logic.
So if you don't change the source files, the logic will be the same.
If you don't change the seed, the placement will be the same.
thanks for the valuable info!
How can I know the seed, which was used for the each compilation?
If I'll set the SEED as you mentioned
set_global_assignment -name SEED 42
and will not change neither RTL nor QSF (constraints), will I be guaranteed that the final Netlist, Route and Timing be same after each project compilation (with the same SEED)?
How can I read the SOF/JIC timestamps using the System Console?
