15 years agoSo, from the pictures I assume you are running both CPU and SDRAM with 100MHz, using the altera-provided SDRAM-controller?
When you compile the hardware, what is the result of the timing analysis? Any red warnings? You are right, most probably it's the clock shift. For my 100MHz-system I have to use some 306°, but it depends from the constraints defined in my .SDC file (I'm using timequest to determine setup/hold slack to be about the same size).
