Alex70
4 years agoRemote Programming don't work - Unable to connect to Quartus Programmer JTAG-Server
Hello Support-Team,
I want program my FPGA over a JTAG-Server. I try everything I found in the Forum to make it run, but I still get "unable to connected".
On both PCs (Remote / Local) I inst...
YuanLi_S_Intel
4 years agoLooks like the flow to setup is correct but the connection is not up. Can you check your firewall restriction? Probably can try allow a program by "Add a Program dialog box, browse to <Quartus II installation directory>/bin/jtagserver.exe".
- Alex704 years ago
OK, it was the Firewall-Setup. There was an incomplete setting. I add now both directions. Now it works fine.
Thanks and best regards
Alex
