roberto_udcNew Contributor4 years agoInferring DSP pre-adders and post-adders in VHDL Hello, I have isolated my problem in a very simple piece of code: entity pruebas is port( a, b : in unsigned(26 downto 0); b : in unsigned(7 downto 0); res : out unsigned(53 dow...Show More
Recent DiscussionsTensor block usageWhen you double click on a word, the other instances do not highlight due to the Find Box being openjtagserver.exe causing BSOD together with ftdi driverAutomatically added negative node for TDS output doesn't work with Agilex 5Agilex3 - unknown IDCODE
