davidyu1
3 years agoCompilation fail duo to hps_csdram_p0
We used platform designer and use hps IP to build our design.
But Compilation failed and had the following message:
Error: The auto-constraining script was not able to detect any instance for cor...
aikeu
3 years agoHi davidyu1,
I am referring to this link:
https://gist.github.com/addisonElliott/8c229e47184a724d1a00328110dc094c
Under Building the project, there are a few steps before step 7 which you might need to perform after you have compile your qsys design in order to avoid the errors.
Aik Eu
davidyu1
3 years agoHi Aik Eu,
When I followed these steps from the link you metioned, running hps_sdram_p0_pin_assignments.tcl had the similar error.
I have attached the screen shot file to the post.
David Yu
