AEsqu
Contributor
4 years agorapid recompile (signal tap logic analyzer flow) : out of memory
When I use the rapid recompile (signal tap logic analyzer flow, quartus std 21.1.0 Build 842) : out of memory (even with 64 GB or RAM).
Cyclone V FPGA, used at around 50%.
When I use the normal c...
ShengN_altera
4 years agoHi Alex
Probably larger RAM memory is required for rapid recompile of Synplify VQM. Since there is no extra RAM available with you for now you may stick with normal compilation first.
Let me know if the problem still exists even after expanding the RAM memory.
Let me know also if any further updates or concerns.
Best Regards
Sheng
