AEsqu
Contributor
4 years agorapid recompile (signal tap logic analyzer flow) : out of memory
When I use the rapid recompile (signal tap logic analyzer flow, quartus std 21.1.0 Build 842) : out of memory (even with 64 GB or RAM).
Cyclone V FPGA, used at around 50%.
When I use the normal c...
ShengN_altera
4 years agoHi Alex,
May be you can check in task manager real time memory usage during rapid recompile. Is there any spike up consumes and exceeds the whole 64GB RAM?
Best Regards
Sheng
- AEsqu4 years ago
Contributor
Hi Sheng,
Yes that was the case.
I don't use rapid recompile but normal compile for now.
See attached picture.
Alex.
