AEsqu
Contributor
4 years agorapid recompile (signal tap logic analyzer flow) : out of memory
When I use the rapid recompile (signal tap logic analyzer flow, quartus std 21.1.0 Build 842) : out of memory (even with 64 GB or RAM).
Cyclone V FPGA, used at around 50%.
When I use the normal c...
ShengN_altera
4 years agoAlex,
May be you can delete db and incremental_db file (Standard/Lite) or qdb file (Pro) then recompile again. If the error still persist, may be you can try with larger RAM memory because place and route stage usually consumes more RAM compared to others.
Best Regards
Sheng
AEsqu
Contributor
4 years agoHi,
rapid recompile is not available when deleting the incremental_db/db directories, which makes sense.
Turning off smart compilation does not help.
Note that the normal compile flow uses about 10 GB.
Looks like there is an issue with rapid recompile in certain RTL code situation.
I had no issue with rapid recompile before I added a Synplify VQM,
which fills much more the FPGA, but still. Maybe that rapid recompile has issue when .vqm is used.
