AEsqu
Contributor
4 years agorapid recompile (signal tap logic analyzer flow) : out of memory
When I use the rapid recompile (signal tap logic analyzer flow, quartus std 21.1.0 Build 842) : out of memory (even with 64 GB or RAM).
Cyclone V FPGA, used at around 50%.
When I use the normal c...
ShengN_altera
4 years agoAlex,
May be you can delete db and incremental_db file (Standard/Lite) or qdb file (Pro) then recompile again. If the error still persist, may be you can try with larger RAM memory because place and route stage usually consumes more RAM compared to others.
Best Regards
Sheng
AEsqu
Contributor
4 years agoOk I will try to delete db / incremental_db then see if rapide recompile works.
I noticed on the web that quartus has rapide compile issue with smart recompile enabled (set_global_assignment -name SMART_RECOMPILE ON) (which keeps data in incremental_db).
It has maybe not been fixed yet?
