9 years agoquestions about buffer size and parameter size.
I am implementing sparse matrix multiply on Nalla 510t, and have some problem transfer my matrix. The problem has I stripped the matrix into 512 pieces for parallel computation. First I trie...
9 years agoYou need to break up your data into smaller workgroups within the total NDRange. Use required or max workgroup size attributes and launch the kernel appropriately to support the workgroup size you've selected. See the best practices guide for info on setting a workgroup size.
