Questa Starter Edition License issues
After following the steps to get a license I get the following when trying to application:
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
When I run the lmutil lmdiag command I get the following:
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Fri 5/20/2022 15:33
License file: C:\intelFPGA_lite\21.1\questa_fse\win64\082221_License.dat
This message doesn't help in identifying the issue, can you provide a solution?
Why does setting up a free version of this application have to be so complex
1 Reply
- Zawani_M_Intel
Hi TimR,
There are issue with Questa license generated recently.
I believe that the issue has been resolved.Could you help to apply again Questa license in Self Service Licensing Center https://licensing.intel.com/ ?
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.Thank you.
Wani
