Questa Sim Licensing - cannot proceed MSCVR120.dll
- 4 years ago
Hello
Welcome to Intel forum. An error code (MSVCR120.dll is missing) usually happens when an application on Windows is missing. You can try the methods below and see if they can help.
1) Reboot your computer
2) Run your application as administrator
3) Reinstall your application
4) Reinstall Microsoft .NET framework (for Windows 7 or below)
5) Reinstall Microsoft Visual C++ Redistributable Packages
6) Update your Windows
7) Run check disk
Switch to ChromeOS Here something that I think might be useful https://www.drivereasy.com/knowledge/best-solutions-to-fix-msvcr120-dll-is-missing-in-windows/#:~:text=Fix%202%3A%20Reinstall%20the%20Visual%20C%2B%2B%20Redistributable%20Packages&text=dll%20file%20belongs%20to%20the,download%20the%20packages%20from%20Microsoft.
Step 4 worked to fix the missing .dll thank you!
