Questa Intel FPGA starter edition (fail to launch the software)
With the license I have confirmed the Variable name(LM_LICENSE_FILE) and the Variable value(complete with the file name) and the path in quartus prime.I run lmutil lmdiag but there's only one line showing my license path.But I can't restart and launch the program and I'm anxious to find out why.
- leonardo_forum
Same issue, the generated license is not working. I opened a ticket for support by Intel, maybe you should do the same.
- HSpen
same here
- david_joslin
I'm also having this issue. Looking at the license file itself in a text editor, the file doesn't look populated with the relevant information for launching the QuestaSim simulator.
- david_joslin
Hi there,
It seems other people are having the same issue. I found this a comment on a similar post that might fix your issue:
intel.com/t5/Intel-FPGA-Software-Installation/Questa-Starter-Edition-Bad-License-File-Generated/m-p/1377115#M3777
Basically, log back onto the self-service license website and re-generate the license file until you get a license file with more than just comments (it will look different from what was originally generated).
- david_joslin
Sorry for the broken link above. Here's the correct link:
community.intel.com/t5/Intel-FPGA-Software-Installation/Questa-Starter-Edition-Bad-License-File-Generated/m-p/1377115#M3777
- leonardo_forum
I tried 7 times and all generated licenses were bad. Hope they can send me a Stratix dev kit with the license.
