Quartus Pro 22.2 SystemVerilog: argument of size should be an identifier
- 4 years ago
Check this https://www.intel.com/content/www/us/en/docs/programmable/683236/22-2/verilog-and-systemverilog-synthesis-support.html so latest SystemVerilog supported is SystemVerilog-2012. Then can refer to IEEE Standard 1800-2012 check here http://www.ece.uah.edu/~gaede/cpe526/2012%20System%20Verilog%20Language%20Reference%20Manual.pdf (page 604) under section 20.7 Array querying functions. You can see array_identifier is mentioned. There are some examples under that section as well for your reference.
This code can be synthesized in simulator. I tested in Questa Starter Edition with no problem. So means this is something supported in testbench. If so should be no problem too as testbench normally is not included in Quartus tool for compilation. Vivado 2021.2 still fails to synthesize $size but able to synthesize $bits. Check the images attached.
Sheng
Sheng
- alexislms4 years ago
Contributor
Considering IEEE1800-2012, now it explains why $bits (defined with $size in 2017's) works and not $size.
The fact Vivado shows an error for this simple case doesn't mean it isn't or shouldn't be supported.
None of $size and $bits are synthetizable. $bits is evaluated at the elaboration, not synthesized.
You can close the issue, thank you for the more convincing arguments.
