BMart12
4 years agoQuartus Prime Standard Edition
I am using 18.1.0 Build 625 09/12/2018 SJ Standard Edition. I accidently punched a button or buttons combination while navigating in the QP screen and goofed up the window layout. I search...
- 4 years ago
Define "goofed up the window layout." Can't you just drag things back the way you want them?
sstrell
4 years agoThere are 3 little buttons for most of the smaller windows in the interface: pin, detach, and close. And as mentioned, you can drag detached windows on top of other windows to create a tabbed layout or put them to the side of other windows.
BMart12
4 years agoActually I was fiddling with the three little buttons but when I dragged the message window, I could not get a blue area to light up at the bottom until your original reply arrived. I have had this problem before and was able to restore the message window to its accustomed position. Today I was not getting there.
Thank you for your support.
