Quartus Prime Standard Edition
- 4 years ago
Define "goofed up the window layout." Can't you just drag things back the way you want them?
Goofed up means I undocked the message window, which used to be at the bottom below the compilation report window. Your question of can't I just drag things back the way I want them inspired me to try it. I was able to get the message window back to where I normally have it. I am guessing that the answer to my original question is no.
Thanks for prompting me to fix my layout.
There are 3 little buttons for most of the smaller windows in the interface: pin, detach, and close. And as mentioned, you can drag detached windows on top of other windows to create a tabbed layout or put them to the side of other windows.
- BMart124 years ago
Actually I was fiddling with the three little buttons but when I dragged the message window, I could not get a blue area to light up at the bottom until your original reply arrived. I have had this problem before and was able to restore the message window to its accustomed position. Today I was not getting there.
Thank you for your support.
