GLT1
4 years agoQuartus Prime Pro 21.3: Platform Designer Problem
I'm trying to add a "generic component" into Platform designer that basically just passes Avalon agent signals through in order to access an external device.
Platform designer doesn't report any ...
- 4 years ago
I try to recreate the example design attached in platform designer.
I found out that if outputenable port under avalon_slave_0 is removed the errors disappear and HDL can be generated. The errors come out if outputenable port is added.
GLT1
4 years agoSheng,
I replaced the oe_n signal with a read signal and it now seems to be working OK. Do you know if that is something that will be fixed in an upcoming version of Quartus Prime Pro?
Thank you!
Terry
- ShengN_altera4 years ago
Hi Terry,
Don't have much idea yet. Need to wait for official finalized released notes or documents.
Sheng
