Quartus Prime Pro 21.3: Platform Designer Problem
- 4 years ago
I try to recreate the example design attached in platform designer.
I found out that if outputenable port under avalon_slave_0 is removed the errors disappear and HDL can be generated. The errors come out if outputenable port is added.
Sure,
The attached qar is slightly different than the original one I posted. This version uses the component editor instead of the generic component (HDL) method. Both methods result in the same error message.
The Qsys file is in the src folder (my_qsys.qsys). Just open that in the Platform Designer and click "Generate" to reproduce the error.
Terry
- GLT14 years ago
Sheng,
I'll give that a try today and let you know how it goes.
Terry
- RPYoshi4 years ago
Thank you for the solution.
I ran into the same problem but my issue turned out to be a miss-label of a byteenable signal as writebyteenable.
Once this was fixed, the post transform connections were correct.
