GLT1
4 years agoQuartus Prime Pro 21.3: Platform Designer Problem
I'm trying to add a "generic component" into Platform designer that basically just passes Avalon agent signals through in order to access an external device.
Platform designer doesn't report any ...
- 4 years ago
I try to recreate the example design attached in platform designer.
I found out that if outputenable port under avalon_slave_0 is removed the errors disappear and HDL can be generated. The errors come out if outputenable port is added.
ShengN_altera
4 years agoHi,
Some warnings showed up as well when i try to generate HDL of the sample file provided. Those warnings indicate that some ip files do not exist. Most likely these errors are caused by those missing ip files.
Make sure license is properly installed and not expired as well. And then try to recreate the design file.
Sheng
