FMCC
4 years agoQuartus Prime Lite not showing circuit node name from from Block Diagram/Schematic File
I teach at a college where we used Quartus II and Cyclone II boards to make digital circuits. I'm evaluating Quartus Prime Lite and a replacement board, the Cyclone V. The software looks to be quite ...
SyafieqS
4 years agoBelow are step to manually install USB blaster for window
Hopefully it helps
https://www.terasic.com.tw/wiki/Intel_USB_Blaster_II_Driver_Installation_Instructions
FMCC
4 years agoHello SyafieqS,
We were able to download the driver to the board however the program failed to download to the board.
I'm looking for an error code to troubleshoot.
Any thoughts?
- FMCC4 years ago
Hello SyafieqS,
I found the issue. The switch on the board had to be in the RUN position. I had it in the PROG position earlier. This was a hale mary test but it finally worked.
Thanks for the help.
Roger
