FMCC
4 years agoQuartus Prime Lite not showing circuit node name from from Block Diagram/Schematic File
I teach at a college where we used Quartus II and Cyclone II boards to make digital circuits. I'm evaluating Quartus Prime Lite and a replacement board, the Cyclone V. The software looks to be quite ...
FMCC
4 years agoSo when I'm in the pin planner this is what I see.
When I select Hardware Setup...
Windows chimes when the Cyclone V board is turned on however it does not look like Quartus recognizes the board. Any thoughts?
sstrell
4 years agoAnything in the "Currently selected hardware" pop-up?
If not, Windows did not recognize the USB blaster. Go into Device Manager, delete the unknown device and try having it auto detect again (unplug and replug). If that doesn't work, you may need to manually install the driver.
- FMCC4 years ago
I think you have found the issue. When looking at Devices on my PC it states 'USB-Blaster, Driver is unavailable'
I need to search for a driver.
