Quartus Prime Lite not showing circuit node name from from Block Diagram/Schematic File
So when I'm in the pin planner this is what I see.
When I select Hardware Setup...
Windows chimes when the Cyclone V board is turned on however it does not look like Quartus recognizes the board. Any thoughts?
- sstrell4 years ago
Anything in the "Currently selected hardware" pop-up?
If not, Windows did not recognize the USB blaster. Go into Device Manager, delete the unknown device and try having it auto detect again (unplug and replug). If that doesn't work, you may need to manually install the driver.
- FMCC4 years ago
I think you have found the issue. When looking at Devices on my PC it states 'USB-Blaster, Driver is unavailable'
I need to search for a driver.
The driver is included in your Quartus installation and was an option to install when you installed Quartus.
<Quartus version>/quartus/drivers
