Quartus Prime and avalon mm bridge bit width meaning
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- CAlex3 years ago
Contributor
Very detailed and clear answer, I will go through the resources first.
Please forgive me for the might be delayed reply.
Thank you
Reguards.
- CAlex3 years ago
Contributor
I now have a question.
If in FPGA side I have a avalon mm slave IP with 4 32-bit registers, the bridge is linked to the h2f Axi bridge,
so the first reg is addressed as IP_bridge_addr (0xC000_0000 + ip offset)
And in HPS I address the IP like:
uint32_t* reg_ip = (uint32_t*) IP_bridge_addr.
with reg_ip + 1, it is pointed to the next reg or just forward 8 bits?
And how to write an IP with constant regs of each 32 bits wide, like all the Altera IPs and call it in HPS with pointer + x (x means the xth reg) .
Is that related to the ava bridge width and AXI bridge width?
Thank you
Reguards.
