Raphy
4 years agoquartus or signal tap.
any change that i make in signal tap , without connection the project , the project download but nothing is working.
my way to overcome it until now, i create qar file , before create signal...
RichardT_altera
4 years agoWhen you say nothing works, may I know what is not working? Program the device fail? data acquire fail? if any, what is the error that you are seeing?
Try to start fresh with a new .stp file using the different node/signal and see if the same issue persists.
