16 years agoquartus ii internal error!
Hi, In my quartus project, i add some nodes for debug in SignalTap. While a quartus ii internal error occur when i full compile the design after adding nodes. The error information is: ...
16 years agoYou can file a SR to Altera, it looks like a bug.
I had the same kind of error sometimes when I used an output as a clock in signal tap, try to change a few things in your signaltap setup and see if it gets better.
