Quartus II 3.0 installer
Good morning to all,
I'm looking for the installer for Quartus II version 3.0.
Do you know where may I download it?
Thank you
Manuel
- SyafieqS
Sadly I don't have the archive due to EOL-ed. May I know what device are you targeting?
3.0 is pretty old and I suggest to use recent supported Quartus to avoid any issue.
- _AK6DN_
That is a ~really~ old version. Even the Internet Archive only goes as far back as v6.1:
https://archive.org/search?query=subject%3A%22quartus%22
What device(s) do you need 3.0 for? Support for a specific ~old~ device is the only reason to require v3.0.
- Eng_Manuel
I need to modify a project based on the EP20K200EF component. In the project I have also a NIOS II part (designed with the 3.0 version). However, I just tried to download the 6.1 version to understand if it is ok for me.
- SyafieqS
What device are you using? Is that device at least support 13.1 version? 6.0 is pretty old you may use it but at your own risk as there is no longer supported.
- SyafieqS
Let me know if there is any update from previous reply
- FvM
I see that APEXIIKE and APEX20K series are last supported in Quartus 9.0.
Frank - SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
