Quartus help copy paste error
Alex,
Yes I can see that, seem like there a mistake for the keyword.
Let me check this and get back to you.
- AEsqu4 years ago
Contributor
On top of the DOC, I would like to get a concrete example for the QSF.
When I use this it is taken by Quartus:
set_instance_assignment -name EDA_DESIGN_ENTRY_SYNTHESIS_TOOL "Synplify Pro"
If I leave it just like this it says other parameters are required (warning).
When I add this:
set_instance_assignment -name EDA_INPUT_DATA_FORMAT VQM
set_instance_assignment -name EDA_RUN_TOOL_AUTOMATICALLY OFFIt gives a qsf error while loading it.
same with
set_instance_assignment -name EDA_INPUT_DATA_FORMAT "VQM"
set_instance_assignment -name EDA_RUN_TOOL_AUTOMATICALLY OFFWhat are the 3 others correct lines to add in the QSF on top of the EDA_DESIGN_ENTRY_SYNTHESIS_TOOL?
BTW, I use Synplify Premier, but I guess it is equivalent to Synplify pro.
I remember that in the past it was required to mention the Synplify eda tool for quartus to understand the vqm,
but that does not seems the case anymore, so I guess I could live with a qsf without EDA_DESIGN_ENTRY_SYNTHESIS_TOOL actually.
