BLee15
7 years agoquartus_eda crashes (core dump) very often. I have to clean my project before compile to prevent crash
Core dump: Problem Details
Error:
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 409
m_port_info.num_of_dimensions() == 1
Stack Trace:
0x54a7: WSC_PORT::left_bit ...
KennyT_altera
7 years agoSeems like this is known issue. you can refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd09302013_869.html
BLee15
7 years agoChanging output format to other languages significantly modifies top module interface.
It is hard to accept this workaround, as it brings heavy testbench rework.
Verilog HDL: 2D array is unrolled to individual single-wire ports
module top (
raw_clock,
raw_reset,
number,
instruction,
in_5_1,
in_6_1,
in_4_1,
in_7_1,
in_2_1,
in_1_1,
in_0_1,
in_3_1,
in_5_0,
in_6_0,
in_4_0,
in_7_0,
in_2_0,
in_1_0,
in_0_0,
in_3_0,
in_5_2,
in_6_2,
in_4_2,
in_7_2,
in_2_2,
in_1_2,
in_0_2,
in_3_2,
in_5_3,
in_6_3,
in_4_3,
in_7_3,
in_2_3,
in_1_3,
in_0_3,
in_3_3,
in_5_4,
in_6_4,
in_4_4,
in_7_4,
in_2_4,
in_1_4,
in_0_4,
in_3_4,
in_5_5,
in_6_5,
in_4_5,
in_7_5,
in_2_5,
in_1_5,
in_0_5,
in_3_5,
in_5_6,
in_6_6,
in_4_6,
in_7_6,
in_2_6,
in_1_6,
in_0_6,
in_3_6,
in_5_7,
in_6_7,
in_4_7,
in_7_7,
in_2_7,
in_1_7,
in_0_7,
in_3_7,
out_7_0,
out_7_1,
out_7_2,
out_7_3,
out_7_4,
out_7_5,
out_7_6,
out_7_7,
out_6_0,
out_6_1,
out_6_2,
out_6_3,
out_6_4,
out_6_5,
out_6_6,
out_6_7,
out_5_0,
out_5_1,
out_5_2,
out_5_3,
out_5_4,
out_5_5,
out_5_6,
out_5_7,
out_4_0,
out_4_1,
out_4_2,
out_4_3,
out_4_4,
out_4_5,
out_4_6,
out_4_7,
out_3_0,
out_3_1,
out_3_2,
out_3_3,
out_3_4,
out_3_5,
out_3_6,
out_3_7,
out_2_0,
out_2_1,
out_2_2,
out_2_3,
out_2_4,
out_2_5,
out_2_6,
out_2_7,
out_1_0,
out_1_1,
out_1_2,
out_1_3,
out_1_4,
out_1_5,
out_1_6,
out_1_7,
out_0_0,
out_0_1,
out_0_2,
out_0_3,
out_0_4,
out_0_5,
out_0_6,
out_0_7);VHDL: Introduces user-defined type, and kind of output port is changed to BUFFER.
PACKAGE top_data_type IS
TYPE \in\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic;
TYPE \in\_7_0_0_7_type IS ARRAY (0 TO 7) OF \in\_7_0_type;
SUBTYPE \in\_type IS \in\_7_0_0_7_type;
TYPE \out\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic;
TYPE \out\_7_0_0_7_type IS ARRAY (0 TO 7) OF \out\_7_0_type;
SUBTYPE \out\_type IS \out\_7_0_0_7_type;
END top_data_type;
ENTITY top IS
PORT (
raw_clock : IN std_logic;
raw_reset : IN std_logic;
number : BUFFER std_logic_vector(7 DOWNTO 0);
instruction : IN std_logic_vector(15 DOWNTO 0);
\in\ : IN \in\_type;
\out\ : BUFFER \out\_type
END top;
