BLee15
7 years agoquartus_eda crashes (core dump) very often. I have to clean my project before compile to prevent crash
Core dump: Problem Details
Error:
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 409
m_port_info.num_of_dimensions() == 1
Stack Trace:
0x54a7: WSC_PORT::left_bit ...
KennyT_altera
7 years agoSeems like this is known issue. you can refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd09302013_869.html
- BLee157 years ago
Changing output format to other languages significantly modifies top module interface.
It is hard to accept this workaround, as it brings heavy testbench rework.
Verilog HDL: 2D array is unrolled to individual single-wire ports
module top ( raw_clock, raw_reset, number, instruction, in_5_1, in_6_1, in_4_1, in_7_1, in_2_1, in_1_1, in_0_1, in_3_1, in_5_0, in_6_0, in_4_0, in_7_0, in_2_0, in_1_0, in_0_0, in_3_0, in_5_2, in_6_2, in_4_2, in_7_2, in_2_2, in_1_2, in_0_2, in_3_2, in_5_3, in_6_3, in_4_3, in_7_3, in_2_3, in_1_3, in_0_3, in_3_3, in_5_4, in_6_4, in_4_4, in_7_4, in_2_4, in_1_4, in_0_4, in_3_4, in_5_5, in_6_5, in_4_5, in_7_5, in_2_5, in_1_5, in_0_5, in_3_5, in_5_6, in_6_6, in_4_6, in_7_6, in_2_6, in_1_6, in_0_6, in_3_6, in_5_7, in_6_7, in_4_7, in_7_7, in_2_7, in_1_7, in_0_7, in_3_7, out_7_0, out_7_1, out_7_2, out_7_3, out_7_4, out_7_5, out_7_6, out_7_7, out_6_0, out_6_1, out_6_2, out_6_3, out_6_4, out_6_5, out_6_6, out_6_7, out_5_0, out_5_1, out_5_2, out_5_3, out_5_4, out_5_5, out_5_6, out_5_7, out_4_0, out_4_1, out_4_2, out_4_3, out_4_4, out_4_5, out_4_6, out_4_7, out_3_0, out_3_1, out_3_2, out_3_3, out_3_4, out_3_5, out_3_6, out_3_7, out_2_0, out_2_1, out_2_2, out_2_3, out_2_4, out_2_5, out_2_6, out_2_7, out_1_0, out_1_1, out_1_2, out_1_3, out_1_4, out_1_5, out_1_6, out_1_7, out_0_0, out_0_1, out_0_2, out_0_3, out_0_4, out_0_5, out_0_6, out_0_7);VHDL: Introduces user-defined type, and kind of output port is changed to BUFFER.
PACKAGE top_data_type IS TYPE \in\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic; TYPE \in\_7_0_0_7_type IS ARRAY (0 TO 7) OF \in\_7_0_type; SUBTYPE \in\_type IS \in\_7_0_0_7_type; TYPE \out\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic; TYPE \out\_7_0_0_7_type IS ARRAY (0 TO 7) OF \out\_7_0_type; SUBTYPE \out\_type IS \out\_7_0_0_7_type; END top_data_type; ENTITY top IS PORT ( raw_clock : IN std_logic; raw_reset : IN std_logic; number : BUFFER std_logic_vector(7 DOWNTO 0); instruction : IN std_logic_vector(15 DOWNTO 0); \in\ : IN \in\_type; \out\ : BUFFER \out\_type ); END top;
