Quartus cannot run the VHDL file
I download Intel® Quartus® II Web Edition Design Software Version 13.0sp1 for Windows from https://www.intel.com/content/www/us/en/software-kit/711791/intel-quartus-ii-web-edition-design-software-version-13-0sp1-for-windows.html and I download separate files: Intel Quartus Software and Intel® MAX® II, Intel® MAX® V, Intel® MAX® 3000, Intel® MAX® 7000 Device Support. After I install it, I try to design digital systems from the guideline: https://tinyurl.com/ed542ttv . but it cannot run. Any solution suggested?
- sstrell
The screenshot seems to show an error with your simulation tool, not Quartus, and you're not showing the error messages you are getting. Can you show that?
- anonymous661
Hello, it just continues to show like in the screenshot and stops there, no result shows. I try to download the package again and install it but still cannot resolve
- SyafieqS
Lim,
From the screenshot I see you are trying to do simulation with university program wvf. From the document you followed, which par/step produce such result?
By right, there should be a window simulation result pop up after you click functional simulation.
- anonymous661
Hi, the screenshot is the window simulation pop up after I click functional simulation. This is the problem, I wait for a long time, but it execute until there and stops but I don't know what is the problem
- SyafieqS
Hi Lim,
Let me reproduce the issue and get back to you with update.
- SyafieqS
Lim,
It works properly at my end and I cant reproduce the issue.
Since you mentioned it stuck as snapshot attached, may I know if your machine meet all the requirement for system and software supported device used?
You can refer to link below for Minimum Hardware Requirements
- anonymous661
Yes..
- SyafieqS
Lim,
Are you able to work on this? or still need help?
Let me know any update on this.
- anonymous661
yes, I download this version (https://www.intel.com/content/www/us/en/software-kit/666221/intel-quartus-ii-web-edition-design-software-version-13-1-for-windows.html )and it can run
- SyafieqS
Lim,
Glad you are able to resolve the issue.
Let me know if there is any concern or update.
- SyafieqS
